No Spark
Old Oct 23, 2006 | 07:29 PM
brainfreeze's Avatar
Default No Spark
While driving down the road - Vehicle Died - Towed Back - No Spark - Tried a Coil Pack - Still No Spark - Any Suggestions Greatly Appreciated!
Old Oct 24, 2006 | 02:02 PM
Default RE: No Spark
Possible crank sensor, if the ECU doesn't see the crank turning I believe you will get no spark and possibly no fuel.
Mike
Old Oct 24, 2006 | 04:46 PM
geoman's Avatar
Is it possible for you to have scanner hooked up to retrieve codes? A OBDII type would at least give you stored codes related to the engine management system. You might have a blown ECU. Or , as Mike said it could be the crank sensor. Or---- it could be the cam position sensor. That is why the scanners are so valuable these days.
It is unfortunate that the complexity of modern vehicles has eliminated the shade tree mechanic approach of following a basic troubleshoot, but this is just the reality.
Regards,
Geoman
www.eurotekapg.com
mikedemet
Jan 29, 2021 02:02 PM
ITMagician
Jun 12, 2006 08:37 PM
mikedemet
Mar 7, 2006 12:07 AM
2002DiscoII
Jan 13, 2006 12:29 PM
kfordric
May 30, 2005 11:29 PM
