No start
Old Mar 29, 2026 | 09:56 AM
Brat's Avatar
6th Gear
Default No start
Hello from Costa Rica, I have a 2002 disco 2 4l gasoline with codes and no start. Code reader doesn't give the numbers for the codes but written as follows
1: permanent voltage supply faultdrive cycle a (I think that showed up after a lot of cranking the motor over)
2: Anti-theft alarm serial link drivefault cycle a
Symptoms....
cranks but no start
no power at fuel pump
no immobilizer light or hazards blinking
engine light on (even though reader says no faults after clearing)
I have checked relay under the hood (swapped with a new one)
relay on inner drivers side fuse box
all fuel related fuses
Checked cutoff switch on firewall.
Tried entering the eka code with key but no beep or flash of red dash light after holding in unlock for 5 secs (did the code anyways and no go) new drivers door accuator (lock mechanism)
Ran perfectly yesterday and this happened after sitting over night in driveway.
Have just noticed no rpm showing while cranking
I live in Costa Rica now and parts are not available here and I am desperate to get her running.
cheap scan tool
Any help is appreciated.
Old Mar 29, 2026 | 09:51 PM
Harvlr's Avatar
I think the immobilized state is the key. Did you enter the EKA correctly? You may need something like a Nanocom to correct it.
Old Mar 30, 2026 | 06:43 AM
Brat's Avatar
6th Gear
Yes I did try to enter the eka code in the proper sequence but it never accepted going into the mode to accept it. No flashing alarm light and no beep.
I ordered a Nanocom yesterday but will take awhile to het it so was hoping for a solution before then.
Thank you for the reply.
Old Mar 30, 2026 | 06:40 PM
Extinct's Avatar
Lock and unlock the vehicle three times with the key
Kurgan
Jul 10, 2024 06:38 PM
Evanblanc
Jan 11, 2019 07:38 PM
pecosriver
Apr 28, 2014 02:13 PM
30more
Nov 27, 2012 09:40 PM
Ghostsoldier
Jul 16, 2012 07:48 PM
