No start issue
Old Feb 8, 2020 | 12:07 PM
Adam51282's Avatar
Default No start issue
I bought a 1999 d2 non sai. It was “immobilized “ and that’s why I got it cheap. I read the eka code on nanocom and entered it with the door method and it turned the alarm off but this thing will not start. No power to the fuel pump or injectors. I’ve tried everything from relays to crank sensor and fuses. The pump does work. I’ve powered it directly. I have some screenshots off the nanocom. I’m lost. I need to get this thing started. I don’t know what do to. I need some real world step by step help to test this issue. My last step is getting another bcu and programming it with nanocom.
Old Feb 8, 2020 | 05:36 PM
Adam51282's Avatar
Issue solved! Found a corroded broke in half wore under the engine bay fuse box. It was the white wire with green stripe to the inertia switch. Mended the wire and it fired right up!
HBW1020
Off Topic
Oct 7, 2016 05:30 PM
TRIARII
Off Topic
Sep 28, 2016 03:30 PM
TOM R
Off Topic
Apr 28, 2016 03:39 PM
bigu
Jun 13, 2009 08:24 AM
