No start issue - cracking n spark but alarm code?
Old May 19, 2024 | 07:08 PM
Extinct's Avatar
There are spacers that go on the studs behind the cps, lots of people put the spacers on before the sensor and it spaces the sensor out too far to work.
Old May 20, 2024 | 08:43 AM
Turbo Arbitrageur's Avatar
interesting maybe I’ll double check that while I am waiting for my ignition part. Thanks!
Old May 22, 2024 | 08:03 PM
I pulled the cover off and there are two large spacers to get the cover away from it, which I have after the sensor to space the cover away from it. Is there more spacers? Is there some other ones… I didn’t pull the sensor out yet. Was just checking it quick. But I do have two large spacers after the sensor if that is what you were talking about?
Old May 23, 2024 | 10:25 AM
Extinct's Avatar
Sounds like it is installed correctly, you said you changed it?
Old May 27, 2024 | 08:46 AM
I just finished swapping the old CPS back in just to troubleshoot. Still no start and I have recurring Idle Air Control code...could a bad solenoid cause a no start?
Old May 27, 2024 | 04:46 PM
Extinct's Avatar
No, that won't do it. Suggest you check to make sure fuel pump is running, maybe check fuel pressure at schrader valve on manifold.
Old May 27, 2024 | 06:17 PM
thanks…didn’t think it would cause a no start. Ordered a couple coil packs. I’ll check fuel situation also. I can smell fuel. Cracking well, I think has fuel pump is working… so guessing something wrong with the sparking?
Old May 28, 2024 | 11:09 PM
TCbaby's Avatar
5th Gear
I had a similar no start condition with wrong immobilizer code error. It resolved by disconnecting the battery overnight and the ECM synced with the BCM again.
Old Jun 2, 2024 | 04:29 PM
Ripped my intake off to install new coilpcks and check wires. What is this silver L pipe with threaded end for? I believe just ripped the intake off and noticed nothing hooked on to that. Seems suspect?
Old Jun 2, 2024 | 06:35 PM
JohnZo's Avatar
Look in the end with a mirror. Tell us what you see.
