No start please help
Old 02-12-2007, 08:40 PM
sydskier006's Avatar
5th Gear
Default No start please help
Hi guys,
maybe you can help me out here, i'm on countless fourums and no resolution. first of all my starter is good, ignition switch good, no imobiliser problem, not the starter relay, not a blown fuse, not grounds, and not the battery. ok so my car is not getting power to the starter and will not start, any ideas? any help would be great, thanks. 95 disco auto.
by the way hello to everyone!
Old 02-12-2007, 09:11 PM
Default RE: No start please help
Have you taken a set of jumpers to the starter to confirm it des work?
Mike
Old 02-12-2007, 09:53 PM
5th Gear
it has been out of the car, in the car, on top of the car, and you name it it is good
Old 02-13-2007, 10:46 AM
So, am I correct in thinking the starter turns over but the engine won't start? If so, have you tried shooting some carb spray or starting fluid into the t/body, will that allow it to satrt for a moment?
Mike
Old 02-13-2007, 10:47 AM
5th Gear
no the starter gets no power so is does nothing
Old 02-13-2007, 10:53 AM
5th Gear
but i know it is good because it has been tested on and off the car
Old 02-13-2007, 11:31 AM
I am stumped, don't know where to go with this problem.
If you try to sart the engine with your headlights on, will they stay up at full power or dim down?
Mike
Old 02-13-2007, 06:27 PM
geoman's Avatar
Have you put a socket on the crank pulley and confirmed that the engine can be turned over by hand?
Sounds obvious, but I've seen more than a few cases of people tearing their hair out trying to turn a engine over that was locked up.
Geoman
www.eurotekapg.com
Old 02-13-2007, 06:42 PM
V8 Disco's Avatar
You might want to take a look at the immobiliser 'spider'; it'sa separate black box under the centre of the dash sandwiched between the radio and the heater. It controls power feeds to starter motor, fuel pump, ignition, fuel cut offetc depending on whether diesel/petrol. They are well known for having problems caused by dry solder joints and can either be repaired or replaced with a jumper plug that takes the troublesome box out of circuit. A quick google on 'discovery spider' or 'AMR4889' should give you the links you need. Good hunting!
EDIT: I re-read your original post and noted that you state no immobiliser problem.. IIRC the 'spider' is separate from the main immobiliser.. so might still be the issue. This is a common no-start/intermittent cut-out issue, so bad in fact that LR created the jumper plug as a factory modification to eliminate the 'spider'.
Old 04-16-2007, 12:22 AM
Discoqueen's Avatar
We had a similar problem, it turned out to be our alternator. Because our starter was good but wasn't getting any power. Checked double checked the battery and finally checked the alternator. Let me know how it turns out.
Discoqueen
Quick Reply: No start please help
