No tail lights on 2000 Disco 2
Old Oct 29, 2009 | 06:32 PM
robdog's Avatar
3rd Gear
Question No tail lights on 2000 Disco 2
Hello, just asking for a lil' help. I believe that the tail lights are associated w/ a relay in the Engine fuse box. Unfortunately the owner's manual does not address relays. It addresses only the fuses. Help please on this issue???:help:
Old Oct 29, 2009 | 07:02 PM
There is a common problem with early DII's, the drivers side tail light leaks and water gets into the tail light assembly shorting it out.
The passenger side tail light piggy backs off of the drivers side.
Remove the drivers tail light and look for corrosion in the light assembly and wire harness.
If you pay attention to other DII's the drivers tail light will be dimmer than the passenger side, theirs will fail too.
On some of them you can see water sloshing around inside the light.
Old Oct 30, 2009 | 11:09 AM
robdog's Avatar
3rd Gear
Thumbs up
Thanks for that tip. I will check this out.
rambo
Oct 17, 2013 10:13 PM
Doral300sc
Feb 6, 2010 03:59 PM
Aj6543
Sep 4, 2009 10:37 AM
DiscoverAU
Jul 10, 2008 09:24 PM
klh113
Dec 17, 2007 02:13 PM
