No tire rotation info in owners manual
Old Feb 28, 2010 | 02:40 PM
mishon's Avatar
Default No tire rotation info in owners manual
Why is there no tire rotation info in the owners or repair manuals for the Disco II
Old Feb 28, 2010 | 04:25 PM
Because tier rotations are now always front to back, same side.
Old school was rotate all 5 tires, but now it is recommended only 4, front to back.
Old Feb 28, 2010 | 05:55 PM
lipadj46's Avatar
My understanding is sront to back is generally for directional tires. If you have a full sized spare doing a 5 tire rotation as it will increase your overall tire life. Rotate often.
Old Feb 28, 2010 | 08:04 PM
mishon's Avatar
thanks for the info....i am getting uneven wear on the front tires, inside left and outside right, the back tires are wearing evenly and all 4 are just over 1 year old. would a lack of rotation cause uneven wear or am i looking at possible suspension issues? i plan on doing an alignment before changing tires and then maintaining a good rotation schedule, but if i do have suspension problems would like to address that sooner than later....thanks fellas.
Old Feb 28, 2010 | 08:09 PM
You have suspension issues.
Your spare will last forever if you dont rotate it into the mix.
If you do next time you need tires you will be having to buy 5 instead of 4.
So instead of spending $800 you will spend $1000.
Now lets add that if you spare is not the exact same brand/tread design of the other 4 tires you are looking at messing with the trucks stopping and handling.
Old Feb 28, 2010 | 08:19 PM
mishon's Avatar
gotit....what type problems do you think i'm looking at with the front suspension?
Old Feb 28, 2010 | 09:01 PM
lipadj46's Avatar
How many miles and what shape are your shocks and springs in? I had uneven tire wear from worn out springs.
Old Feb 28, 2010 | 09:10 PM
mishon's Avatar
120,000mls and i have'nt looked at my shocks or springs as yet..
Old Feb 28, 2010 | 09:16 PM
lipadj46's Avatar
That would be number one on your list, you are overdue for new springs and shocks.
Could be bad shocks and/or springs, bad ball joints, tie rods, tire pressure, caster/camber, toe-in, toe-out...could be almost anything.
Your best bet is a free estimate from a suspension shop before you do anything else.
