noise
Old Feb 14, 2008 | 05:15 PM
newdr's Avatar
Default noise
sounds like i have a bird in the dash behind the right airflow vent.
not all the time but when the air flow is high.
thoughts?
Old Feb 14, 2008 | 07:22 PM
Default RE: noise
Junk in the blower motor, behind and below the glove box.
Old Feb 14, 2008 | 07:50 PM
Luv2Disco's Avatar
Default RE: noise
Let's hope that's all it is. The blower had to be replaced on my 02. keep an eye on it.
Old Feb 15, 2008 | 08:59 AM
Default RE: noise
No, don't keep an eye on it, remove it and clean it out before it fails.
Old Feb 22, 2008 | 02:03 PM
newdr's Avatar
Default RE: noise
is cleaning a due it yourself?
difficult?
Old Feb 22, 2008 | 02:44 PM
Default RE: noise
Sure, it is easy to get in there and remove it. Once you get it out you can check for junk in the or spin the blow cage and see if a bearing is failing.
david4ducati
Mar 1, 2015 07:59 PM
30more
May 28, 2012 05:01 PM
adrianwood
Freelander
Jun 13, 2005 08:53 PM
