Noob lift question
If i could get a 3" lift for around the same price i would do it. Or would it be smart to get the 3" spring and shock but not get the rear links and front radius arms?
Thanks
Could do a 2" lift then add 1" spacers to give around 3" of lift. Personally I think a 2" lift with bigger tyres is enough for most people. If you go that high (3") you will probably "eat" propshaft rotoflexes and you will also need extended brake and ABS lines aswell, infact on my D2 I just exteneded the brake hoses with a 2" lift as they were at max stretch with the new Terrafirma +2" shocks installed
