Not changing gears and codes P0155 and P0171
Hello guys,
My wife started to complain about no changing to higher gears on her
99 Disco II (50 k miles), lack of power and misfiring noise.
I checked sparking plugs and gearbox oil and it’s OK.
I didn’t get any check engine lights on panel but after a scan I got P0155 (O2 front sensor RH Bank) and P0171 (System too rich LH Bank).
The car is misfiring and has a strange noise at idle, like a leaking in the admission. I tested the car on street and it doesn't go over 3000 rpm and 50mph.
What do you think? Do I need new O2 and MAF sensors ? Any other ideas?
Thanks
J Reali
East Timor
Thanks
J Reali
East Timor
Just an update
Mike,
just an update:
I changed transmission oil and filter and the gear change is a little better. Still delaying changes specially when cold. I cleaned the codes yesterday and today I got P0150 instead of P0155 and P0171.
I'm waiting for the O2 sensors to arrive from AtlanticBritish. Once I change them all I come back to report.
Thanks for your help.
just an update:
Not changing gears
OK Mike, here it is:
I changed transmission fluid and O2 sensors. The strange noise is also gone. It was a leak on the exhaust manifold now solved. The problem now is: Still not changing gears adequately. If you push hard the gas pedal, rpm goes up to a limit of 3000 but the gears doesn't go up. It only change gears when you release the gas pedal.
But if you push gas pedal progressively, then shift all gears in an apparently normal way. What do you recommend as next step?
Thanks again
J Reali
99 Disco II in East Timor (40k miles)
Thanks again
J Reali
