O2 or MAF??? Help...
Old Jun 12, 2013 | 04:31 PM
Leej's Avatar
Default O2 or MAF??? Help...
Hi
I'm having some problems with O2 sensors and I need some help. I have searched other threads and read through them, and while the info has been helpful, I don't seem to be finding a clear solution...
I have a 2000 Discovery II, with 90,000 miles. I had replaced O2 sensors about 3 or 4 years ago, but recently engine light came on and codes indicated O2 Sensor (Bank 1 Sensor 1), so I replaced both front (pre-cat) O2 sensors. Then, after a few miles, I got more codes indicating BOTH front sensors and I assumed I had just received bad O2 sensors. So I returned them under warranty and replaced again (black box from Amazon with orange OEM connectors), and then after 15 miles or so, I'm now getting the following codes:
P0130 O2 Sensor Circuit (Bank 1 Sensor 1)
P0150 O2 Sensor Circuit (Bank 2 Sensor 2)
P1129 O2 Sensors Transposed ???
P0174 Lean (Bank 2)
P0171 Lean (Bank 1)
P1174 lean?
P1171 lean?
I've checked the connectors and sprayed them with contact cleaner, I don't believe they are dirty or oily. I can't find any vacuum leaks (maybe I am missing something). Didn't see any wiring issues. Spark Plugs and wires were replaced 3 years ago.
When I watch the O2 status on a code reader, it is changing, but not by much, seems to stay around .2 for both front sensors?
I can't believe that I have received 4 bad sensors (maybe?), and I assume there is something else going on????
Could it be the MAF (I hate to replace it without being sure)??? Is there anything else? Maybe I am just missing a vacuum leak?
Any suggestions? Thanks!
Lee
2000 Discovery II
90,000 miles
Old Jun 12, 2013 | 05:56 PM
jafir's Avatar
Maybe an exhaust leak? Did you have to remove the y-pipe the get the sensors replaced, or were you able to do it in place?
I get the P1171 and P1174, and I'm SURE I've got an exhaust leak at where the y-pipe meets the manifolds. I can feel it when it's on the lift. I was going to try to tighten them up, but I noticed one or more of the studs are missing, so I just ordered 6 nuts and studs from rovahfarm. (I already had the gaskets) I'm hoping this fixes me up.
Old Jun 13, 2013 | 09:13 AM
It is not your MAF.
As already mentioned, start checking for exhaust leaks.
Old Jun 13, 2013 | 09:40 AM
Leej's Avatar
I'll check for exhaust leaks, but I did not remove y-pipe when sensors were changed. Stupid question - I presume I'm looking for a leak before the sensors and not after(does this make sense) or does it matter?
I'm wondering if I have a connector issues, but seems odd to be on both sides...
Also, when I pulled the sensors the second time, they seemed pretty black with soot to have been in such a short time, but I'm guessing that is just a result of the mixture being off which is obviously a result of my problem.
I'll check for exhaust leaks (and also vacuum in case I missed something) and report back.
THANKS.
Lee
Old Jun 13, 2013 | 09:46 AM
jafir's Avatar
You're looking at it correctly, before the sensors is where you'd look for the exhaust leaks.
Old Jun 13, 2013 | 09:53 AM
drowssap's Avatar
if cover your exhaust with a rag it should be pretty easy to find your exhaust leak
Old Jun 13, 2013 | 11:04 AM
dpaller's Avatar
Look at the manifolds for cracks. The passenger side from my understanding is notorious for cracks, not sure about the driver side it is more stout. I have a spare driver side manifold if you do indeed need that. I would look at where the downpipe connects to the manifold, mine cracked on the driver and the passenger separated.
Old Jun 13, 2013 | 05:55 PM
Leej's Avatar
Default still stumped...
I checked for exhaust leaks and didn't find anything.
Looked again for vacuum leaks, didn't see anything...
When I first started the engine and looked at O2 data, Bank 2 sensor seemed to be switching pretty good, but Bank 1 seemed flat at .2. After I drove a few miles, both sensors seemed practically flat around 0 or .1.
Cleared codes and drove a few miles. Pending P0150 and P0130 came back fairly quickly. After a few miles P0171 and P1171... Also idles rough when in gear and smooth when in neutral.
Still stumped... I hate to try another set of O2 sensors, but seems like everything is pointing that direction...
Any thoughts?
Thanks
Lee
2000 DII
90,000 miles
Old Jun 13, 2013 | 08:29 PM
So, since the 171 and 1171 come back, there is no question those 2 front 02's are acting up, not sure where to point you at this point.
Old Jun 14, 2013 | 02:22 PM
jrmdir's Avatar
Not trying to hijack the thread, but, Jafir, please report back if the exhaust work gets rid of 1171 & 1174. I've had them for a while and have mostly been told to get a smoke test. Never thought to look for an exhaust leak but that's on tap for this weekend.
Thanks,
