Which O2 Sensor does code P0154 refer to?
I changed my O2 sensors and I keep getting the same code after clearing it a couple times. I get the code P0154 which I think is bank 2 sensor 1. Can someone confirm? Is this the front drivers side?
I'm going to get a replacement from Atlantic British and just want to make sure I get the correct one.
I did change all 4 O2 sensors, this is the one code I am getting now after changing them, there were no codes before I changed them, I did it as maintenance. I changed the ignition wires to magnecores and the plugs are new.
Should I try a new sensor from Atlantic British?
Does this code mean though that is not even recognizing the O2 sensor (P0154)? It's not the other high temp code, just wondering if it point to a faulty O2 sensor or do I need to take it in to a Land Rover dealer or should I get a new sensor for Atlantic British and try to reinstall it?
Thanks for the heads up,
Brendan
Connections are good I just wanted to make sure P0154 was actually the front passenger side which I'm glad its not the front driver sides because that one was a b!@ch to reach.
154, the ECU sees it but there is no activity from it, as in dead. I would suggest you check and clean the connection, if it is still there then contact whoever you bought them from and get it warrantied.
