o2 sensor remplacement
Old Aug 10, 2014 | 02:23 PM
fmontero's Avatar
7th Gear
Angry o2 sensor remplacement
I need help
I have a land rover discovery 1999 car does not pass emissions because it has the light check engine on, my mechanic told me I had to change the oxygen sensor bank 1, my surprise is that the connector of the sensors were cut , buy new sensors, but not the order of colors or voltages of each wire to place them correctly because it has the plug
The sensor has four wires, black, gray, and two white, but not how to connect them properly
Old Aug 11, 2014 | 05:04 PM
toofaroffroad's Avatar
Buy Sensors that are meant for your truck. They will have plugs that fit in directly with the plug on the truck. Are you trying to wire new sensors on? mistake.
I would also check all 4 sensors to see if any others have been cut. The fact that they've been cut is a worry to begin with. Why would someone do that?
Old Aug 11, 2014 | 05:59 PM
fmontero's Avatar
7th Gear
Default o2 font sensor wirring cable
The original owner cut the both front oxygen sensor male conector, (the o2 sensor included the female conector) I need the diagram, or the voltages to correct connection to the new O2 sensor
The o2 sensor have 4 cables, black, grey, and two white
but I don't have idea to correct connection to the ECU
Thanks for you help
Old Aug 13, 2014 | 01:43 AM
Fallstaff's Avatar
I doubt he'd have cut them before the plugs (mostly because that would be incredibly difficult and someone who did that probably comes down on the lazy side of things).
Can you see the plugs and pull the old ones out? They are really high up and astoundingly hard to unplug (experience talking).
And then yes, buy the right sensors and plug them in.
Old Aug 13, 2014 | 09:20 AM
acamato's Avatar
Download the RAVE and open the electrical library
Look at connectors C0642, C6043, C6044, C6045. These are the connectors for the o2 sensors.
KlamathMatt
Apr 17, 2020 05:27 AM
jfoley1
Mar 18, 2009 06:52 PM
stupid
Nov 23, 2008 01:17 PM
jmccollister
Sep 9, 2008 08:50 PM
Morgan
Aug 14, 2007 08:15 PM
