O2 sensor wiring
Old Jun 26, 2010 | 10:14 PM
twmj1953's Avatar
Default O2 sensor wiring
Need to re wire my two front O2 sensor to the plug. (2000 Disco II) I figure the two white wires (tinned) off the O2 sensor are interchangeable, but the black and gray wires gold plated are specific. The wires off the harness are not gray and black so does anyone know which color wire the black and gray leads go to? Any help would be appreciated.
Old Jun 27, 2010 | 02:19 PM
2 people on the same day trying to save a few bucks? Why are you replacing them, by fault code #, what is the mileage on your truck and how come you are not replacing all 4 if you are around 100,000 miles?
Old Jun 27, 2010 | 03:16 PM
03discoman's Avatar
look at the rave before you post
and the bosch website tells you what the sensor wire hook up should be for a universal 02....look it up
Old Jun 29, 2010 | 08:59 PM
wesley64's Avatar
okay twmj1953,i figured it out.the black wire on your old o2 harness is the signal wire,the grey is the ground,and the two whites are the heater wires.
wow!two smart *** answers and then a a helpful answer.
some people on this forum are no where near as helpful or tolerant of newbies as the jaglovers form.they should check it out and learn some manners
brett
2004 discovery
KlamathMatt
Apr 17, 2020 05:27 AM
dan_t
Aug 6, 2012 11:04 PM
kevin cassidy
Jan 30, 2012 12:42 AM
ttlandroverdisco
Oct 14, 2010 09:44 PM
imaric
Sep 28, 2010 09:04 PM
