o2 sensors Generic universal vs brand name
No such thing as a stupid question, sorry for assuming that everybody knows the difference.
They are the different engine management systems.
http://www.roverparts.com/TechTips/boschvsgems.cfm
ORIGINAL: Spike555
No, only DI's.
GEMS used 4 and BOCSH uses 2.
And no I do not know which way is better.
No, only DI's.
Sorry, but you've got that switched around. The older GEMS system uses 2 (two) sensors and they are located before the catalytic converters. The Bosch system uses 4 (four) 2 before and 2 after the catalytic converters. In general Disco 1 trucks have 2, and Disco 2 trucks have 4.
When you are looking.... If your truck has 2 (two) they will be in the exhaust pipes between the exhaust manifolds and the catalytic converters. If it has 4 (four), 2 of them will be before catalytic converters, and the other 2 will be after the catalytic converters...so If you do not see any after the catalytic converters (between catalytic converters and muffler) then you only have 2.
ORIGINAL: Phototone
ORIGINAL: Spike555
No, only DI's.
No, only DI's.
