obd 2 code reader
Old Feb 18, 2009 | 05:03 PM
malmberg's Avatar
Default obd 2 code reader
I have been looking into getting a code reader for the disco. I have seen a few models but wasn't sure which one to get. I wasn't sure that if the proffesional one with the real time data would be usefull for me. I am on a budget so if I don't need it I can put that money towards the disco. If anyone can recommend a good scanner I would appreciate it.
2000 disco, 102000 miles
Old Feb 18, 2009 | 05:15 PM
Go on line to Atlantic British and pick from one of them and don't buy more then your mechanical knowledge will let you use.
Old Feb 18, 2009 | 05:43 PM
Wal_mart sells a nice one for $100, Harbor Frieght sells cheap ones for $35.
Amazon.com also sells them, any of them will do what you want, read and clear codes, it is better to get one that will tell you what the code means on the screen so that you dont have to look it up.
But just buy the best that you can afford.
Old Feb 18, 2009 | 05:45 PM
discodefender's Avatar
But will they read everything?
three amigos?
I'm thinking of buying one also. Tired of borrowing
Old Feb 18, 2009 | 06:05 PM
malmberg's Avatar
I think they are only for the CEL and not the three amigos. I am just wondering if there are any benefits from having the real time log. I think that I want one that will just read and clear the codes like the equus 3110.
Old Feb 18, 2009 | 06:09 PM
No a OBD scanner will NOT read ABS codes, and the 3 amigos are ABS related...I want a Scangauge.
Old Feb 18, 2009 | 08:36 PM
unimoged's Avatar
I am not sure that the "freeze frame" feature is useful for someone that wants to read / clear codes, so going with a low cost device is not a bad idea.
I am still looking for a low cost scanner that can recognize the SLABS ECU and clear the 3 amigos codes in addition to the engine and transmission. Haven't found one yet.
Old Feb 18, 2009 | 08:54 PM
You will never find one.
It takes a special scanner with special software to read ABS codes.
Your best bet would be to look for PC software and a OBD to USB cable to hook your car to your laptop.
Old Feb 19, 2009 | 01:47 AM
Urban Panzer's Avatar
Nanocom is a low cost option for ABS, SLS, ALARM and the BCU in the Disco 2. http://web.nanocom.it/default_i.cfm Its "designed" for the TD5 as it also does the diesel (swearing, sorry!!) engines.
I just got one recently, god its fun to play with all the options etc, my dashboard now has some new lights and chimes now and I have reconfigured some of the options in the BCU as well.
The good thing is its "upgradable", as they add more modules, you just update the firmware to get them to work. The ACE is currently in development now.
Its very reassuring now to have complete home diagnostics available to me, it's a "stand alone" unit which also does "live" data and it can be used with a pc or laptop and a windows based software.
Old Feb 19, 2009 | 10:25 AM
microbc's Avatar
Default Nanocom with 2000 D2 V8
Hi Urban Panzer,
Will the Nanocom work with gasoline based D2's as well as diesel Disco's?
Can it be purchased in the US?
Thanks,
Art
