OBD gauge to monitor the coolant temp
Old Jun 18, 2018 | 01:22 PM
Aj6543's Avatar
Default OBD gauge to monitor the coolant temp
Can someone recommend an OBD gauge to monitor the coolant temp? Where can I purchase a cheap effective reader?
Old Jun 18, 2018 | 01:32 PM
JUKE179r's Avatar
UltraGuage or UltraGuage Blue... they are somewhat cheap but well worth the money spent on them.
UltraGauge OBDII Scan tool & Information Center
Old Jun 18, 2018 | 02:51 PM
Best4x4's Avatar
ScanGauge II is another good unit & it mounts cleanly under the blank plate/dash cup holder.
Old Jun 19, 2018 | 07:31 AM
ahab's Avatar
I bought a $15 Amazon kitbest WiFi dongle and the $10 OBD Fusion App. I like the setup a lot however there are limitations. It's also important to know that iPhones require a WiFi dongle, Andriod works over bluetooth. It looks like Ultragauge supports either but others may not.
Anyway, I laid out a few dashboard pages with gauges that are important to me however the gauges don't display anything when connected. For example oil temp, fuel pressure and fuel remaining (gal) are things I'd like to know and I can set the software up to display these value by selecting the appropriate PIDs however the displays never receive input data. Is this a limitation of the GEMS ECU and what it will spit out to the software? Essentially what I have is a glorified temp gauge which is fine for the $25 price of admission, as I'm not interested in fuel economy, RPM, or MPH etc. but with that in mind I think the alarm feature of the Ultragauge Blue is still worth the extra $65 for the dongle if that's really what we're limited to. Am I configuring this thing wrong to display the other values or will none of the software packages work to do that because the ECU is incompatible?
Old Jun 19, 2018 | 06:02 PM
Fallstaff's Avatar
I do well with a cheap wifi dongle, DashCommand and an old iPhone touch. Reads all the variables including temp like a charm.
Old Jun 19, 2018 | 11:08 PM
ahab's Avatar
Fallstaff, do you get the three I listed; gallons, oil temp and fuel pressure?
Old Jun 20, 2018 | 04:21 PM
Fallstaff's Avatar
Fuel yes, not sure about oil temp, but if there’s a sensor then it seems to be possible to make a gauge to monitor it. I’ve used it for various troubleshooting problems and you can make custom gauges for any data (or graphs, or whatever else you might want).
Fuel stuff is done by programming it when you fill up (put in cost and volume) and such... never really got it to be useful. But can be done.
Old Jun 20, 2018 | 06:32 PM
ahab's Avatar
Good point. I don't remember seeing an oil temp or fuel pressure sensor in the electrical diagrams so that's not ever going to work. There is a trans temp sensor because it light the dash light when too hot. That might be good to search for. Not sure why I can't get remaining gallons to work. Thanks for the reply.
originalpy
May 4, 2021 09:16 AM
2Discos
Sep 9, 2013 04:23 PM
nvrenuf
May 26, 2013 09:27 AM
drdeadchef
Aug 22, 2012 08:50 PM
Snafu / Disco Fries
Sep 20, 2011 08:24 AM
