OBDII reader good deal
U480 OBDII CAN-BUS Check Engine Auto Scanner Trouble Code Reader - Newegg.com
Ordered that today for 15.99 shipped. Thought it was a good deal.
Also, for anyone in the Charlotte NC area, I have an ABS Amigo V1 USB.
I charge only a case of Coors Light for a reset.
Now if I can only figure out how to get the gas light to stay off....lol
-Todd
-Todd
this one here?
Soliport ELM 327 Bluetooth OBDII OBD2 Diagnostic Scanner : Amazon.com : Automotive
man that is pretty sweet not going to lie...might have to order that for my Galaxy S3...lol
OBDII Trouble Code Reader Needed Please
Dear Sloan74,
I have a 2005 LR RR and am looking for a good OBDII Trouble Code Reader. In fact the one I was looking at was: Universal CAN Pro-Series OBDII Trouble Code Reader - $109.00
What do you think - is there a better one you recommend?
Thanks JP
Works with all 1996 and newer cars & trucks that are OBDII compliant.
Live Data Stream.
DTC (Diagnostic Trouble Codes) meanings are displayed in text mode.
Reads Freeze Frame Data.
Large Backlit LCD Display.
Large Database of Diagnostic Trouble Code(s).
Clears / Turns off Check Engine Light.
Reads VIN number: great for verification of used cars!
Tests I/M Status: Misfire Monitor, Fuel System, O2 System, EGR System, MIL Status.
Reads and clears generic and manufacture specific Diagnostic Trouble Codes (DTC).
Supports multiple trouble code requests: generic codes, pending codes and manufacturer's specific codes.
Highly reliable and accurate.
Easy to read backlit LCD display.
Easy to use with one plug-in.
Safely communicates with the on-board computer.
Stand-alone unit with no need for an additional laptop computer to operate.
FULLY COMPATIBLE WITH CAN PROTOCOL
Thanks JP
Live Data Stream.
I have the ELM 327 and an Android phone The Elm was about $22 It tells me more than i want to know. Since I have 3 vehicles I am getting one for each and entering profiles for each so anytime The Lovely Ms. Slabrat or I are driving, we fire up The Torque App ( 8 - 9 $ ) and set an alarms for for some variables Like Coolant Temp. It will alarm if temp get hi. I have mine set to 215 . I want to know quickly. I normally leave Torque running all the time it sleeps when not plugged into power so it won't run down battery while away from Rovers.
Dear Sloan74,
Thanks JP
Live Data Stream.
Thanks JP
Live Data Stream.
$97.73 & FREE Shipping
It is also capable of reading/resetting ABS and SRS codes.
