Octane
RE: Octane
Octane what you want is the highest for the elevation you are at.
At sea level (900ft) I can get 93 but as I increase elevation the octane goes down,, it has to do with the air that the motor has to use, the higher you go the less air there is.
Octane boosters are good if you get the right kind.
Octane boosters will say they increase octane by say 10 points that means that a 90 octane fuel will go to 91, every 10 points of booster = 1 octane in the fuel.
RE: Octane
Well, you were supposed to be using premium gas the whole time.
And if you were using regular and then adding octane booster to get premium results...not only did it not work you spent just as much as if you had bought a tank of premium.
Your trk has a MINIMUM octane rating of 91. That means nothing less than 91 octane gas should ever go into the gas tank.
By switching to premium you will get better MPG.
Lnghrn Disco
06-14-2007 12:48 PM
