Octane
Old Jul 5, 2008 | 12:43 AM
vinvelasco's Avatar
Default Octane
Will higher octane work better for a high mileage disco? Specifically 91 or 95 octane on a 171+ mile baby. Whats the difference between em anyways?
Old Jul 5, 2008 | 01:24 AM
99LRDisc's Avatar
Default RE: Octane
I dont really know, people say use higher. So i go 91 and 2 bottles of octane boost. While i'm here, what is the best octane boost to use. On my routes dont have the most places that sell higher than 91
Old Jul 5, 2008 | 06:43 AM
Landzu's Avatar
Default RE: Octane
Octane what you want is the highest for the elevation you are at.
At sea level (900ft) I can get 93 but as I increase elevation the octane goes down,, it has to do with the air that the motor has to use, the higher you go the less air there is.
Octane boosters are good if you get the right kind.
Octane boosters will say they increase octane by say 10 points that means that a 90 octane fuel will go to 91, every 10 points of booster = 1 octane in the fuel.
Old Jul 5, 2008 | 06:49 AM
Default RE: Octane
Yes, 91 octone will help but only after the do a full tune up, a set af Magnecor 8 mm wires a crank case flush and most importantly an induction cleaning.
The biggest plus for the older D1's is you can stop building up carbon on your vavlve stems.
Old Jul 5, 2008 | 04:56 PM
Default RE: Octane
Well, you were supposed to be using premium gas the whole time.
And if you were using regular and then adding octane booster to get premium results...not only did it not work you spent just as much as if you had bought a tank of premium.
Your trk has a MINIMUM octane rating of 91. That means nothing less than 91 octane gas should ever go into the gas tank.
By switching to premium you will get better MPG.
99discoII
Sep 23, 2007 08:10 PM
Lnghrn Disco
Jun 14, 2007 12:48 PM
newdr
Jun 13, 2007 05:53 PM
meyersd
Aug 14, 2006 12:32 PM
ferrelltodd
Jan 3, 2006 12:11 PM
