ODB II reader
Old Mar 17, 2007 | 12:05 AM
rover_lover's Avatar
Default ODB II reader
Who can recommend a good ODB II reader. I want one which hooks up to my laptop, if possible. That way it should be cheaper. I thought I had found what I needed when I ordered the Drive Right CarChip. Their tech support told me tonight that this CarChip reader is only good for getting codes that make the "Check Engine" come on. The ABS lights were not supported. One question I have is: The port under the dash, does it give you ALL the codes or is there another connector.
I'll appreciate the help.
Thank you.
Email if needed. thenderson4@bellsouth.net
Old Mar 17, 2007 | 02:08 AM
D2 2003's Avatar
Default RE: ODB II reader
The one I plan to buy "any minute now" is the vehicle explorer. It's not an elf, but the guy who made it seems to know his stuff.
Here's the link: http://www.obd-2.com/index.html
I'd also apprecaite any feedback on this tool.
Another that looks pretty good is the autotap: http://www.autotap.com/
I am leaning toward the vehicle explorer for the more "bare metal" communications available.
Again, like the OP any feedback would be appreciated.
Cheers,
-Keith
Old Nov 11, 2007 | 11:17 AM
rphotographer's Avatar
did this unit work on the ABS,traction control etc, etc.......or just on the engine light?????
Thanks
Ralph
www.ralphduke.com
Old Nov 11, 2007 | 01:22 PM
fire1427's Avatar
I've got a scangauge ... works awesome
Old Nov 11, 2007 | 01:27 PM
You will need to spend $8000 or more for a scanner that can also access your ABS, SRS, SLS and any other functions not related to your engine.
Rovers Test Book is a mear $32,000 plus depending on a few options.
Old Nov 11, 2007 | 02:53 PM
S4poor's Avatar
ORIGINAL: Disco Mike
Interesting. With my VW/Audi OBDIIdongle and software (from Ross-Tech)I can access the ABS module among many other modules and channels.
Don't get me wrong, themain reason I use it on the Disco' is because I already owned it. If I "needed"to utilize it as much as I do for the Audi, I'd buy more specific software.
04BluDisco
Jan 23, 2010 02:22 PM
96roverdisco
Jun 14, 2009 07:45 PM
operez818
Feb 14, 2009 09:34 AM
Tvdmtac
Sep 5, 2007 09:42 AM
s4lex
Feb 16, 2007 04:41 PM
