Odd shifting and hesitation?
I'll just get right to it.
I'll turn the truck on, and as I exit my apartment complex, the truck will hold 1st gear for an unusually long amount of time, and then you can feel second gear slam in. It is very annoying and does not feel good at all.
The other thing...
I'll be at a red light, and on green I take off. At about 45+ mph, the car will have been holding what I assume is second gear, and then the rpms will drop(in 2 distinguishable phases) and I'll feel 2 different gears, third and then fourth and I did not let off the pedal at all. I kept it about half to 3/4 of the way down, and it just completely drops gears and I have to floor it to get it to pick up any kind of speed. Even with sport mode I have noticed these hesitations. What is this? I come from a 5 speed manual sport coupe...maybe I am just being picky? Let me know and any input is, as always, greatly appreciated.
The motor sounds fine as does the transmission. The entire vehicle sounds smooth but it acts "not" smooth. I've done a seafoam once...I might do it again but with an entire can in the induction this time instead of a half. Could that fix it?
Best,
Ashtray
The other thing...
Best,
Ashtray
Don't take this wrong, but leave the MAF alone cause it sounds like you are not very mechanical and you will just cause more issues. Also the MAF will not cause a tranny to slam into gear, only cause it to hunt and shift usually in 3rd. and 4th gears only.
How many miles on the truck, when did it have the last major service?
Do you have a good Rover mechanic you can trust?
But earlier you stated you don't know when the last time the trans fluid and filter was changed...
That is something that would be done during a major service.
So which one is it?
If major service entails a transmission fluid and filter change then I am gonna have to assume it was done at the LR dealer. I'm heading to the dealer this Friday to get all the service records on the truck. Until then is there anyway I myself can check?
