Odd sound, Ehhh?
Old Oct 21, 2012 | 10:27 PM
ZGPhoto's Avatar
Default Odd sound, Ehhh?
There was a little clunk as I was driving down my road so when I parked the truck for the night I climbed under it to tighten a shock mount bolt. While I was under it I heard this... next to the rear prop shaft/transfer case. Like a constant running sound?
Old Oct 22, 2012 | 05:25 AM
That video is no help, better do a better job describing the noise if you want some help.
Old Oct 22, 2012 | 08:08 AM
ZGPhoto's Avatar
How is the video no help, did you watch it? Turn the volume up, you can hear the sound, it's like a buzzing. The video is showing what the part is, and the sound it is making.
Old Oct 22, 2012 | 08:30 AM
Lupin 3rd's Avatar
Do you have SLS (self leveling suspension), aka. air bags on your rear shocks? That could be the compressor running.
Old Oct 22, 2012 | 08:31 AM
drowssap's Avatar
i have to agree with DM, i cant tell if your in the rear or the middle of the truck.
if it in the rear could it be the fuel pump? if your in the middle; did your truck have sls that was converted and it is the compressor? if all else fails pull each fuse one by one until it shut down, then track that curcuit.
Old Oct 22, 2012 | 08:55 AM
ZGPhoto's Avatar
I mentioned in my post that it was right next to the transfer case. I don't believe it had SLS, I somehow doubt it.
Old Oct 22, 2012 | 08:58 AM
drowssap's Avatar
next to the transfer case in a black plastic box?
Old Oct 22, 2012 | 09:15 AM
ZGPhoto's Avatar
Yeah, after checking out microcat for a bit I'm thinking it may be wtb000090 part of the secondary air system/fuel system?
Old Oct 22, 2012 | 09:18 AM
lr2001silver's Avatar
Banned
Does it continuously run or just for a short time?
Old Oct 22, 2012 | 09:24 AM
ZGPhoto's Avatar
For at least a few minutes after I shut it down last night, though I've never heard it before. I only heard it last night because I was under it.
