Odd wires running from fuse box
Old May 20, 2011 | 08:35 PM
cipher982's Avatar
Default Odd wires running from fuse box
Hey guys, I've had a 96 disco for a while now, and just recently purchased a 2001 a few days ago. Doing some basic look-overs today I noticed two odd wires running out of two separate fuses within the engine bay fuse box. It seems like some quick aftermarket attempt to power something or fix a problem?
The red wire runs into the #3 fuse from the left, and the green wire runs into the #4 fuse from the right. Which apparently are Direction Signals/Hazards, and Headlight washers respectively.
Here is a link to the picture I took:
http://img854.imageshack.us/img854/7...eryfusebox.jpg
Old May 20, 2011 | 08:57 PM
Aux power for something or other.
Old May 20, 2011 | 09:10 PM
cipher982's Avatar
Hm, that's weird. Doesn't seem like a smart thing to do, running power from some random fuse locations. I tried tracing the two wires but they just go into the firewall and somewhere in the dash that I can't see. I'll try removing them and seeing if anything changes.
Old May 20, 2011 | 09:54 PM
If you check what those fuses are for it will better tell you what they tried to run.
Are they switched power fuses or non switched?
Switched would be something like the radio, it only gets power when the key is on.
Non switched means it gets power all the time, like the headlights.
My wifes Volvo had a car phone installed when we bought it (the old style car phone if you are old enough to remember those) and they tapped power from the fuse box just like on your truck.
When I drove semi we tapped power from the fuse box for our CB's so they come on or off with the ignition key.
I wouldnt worry about it.
GGhost
Apr 1, 2014 02:47 PM
Blakesrover
Feb 21, 2013 01:43 AM
96DiscoLover
Feb 5, 2008 10:28 PM
Luv2Run
Aug 16, 2005 01:38 PM
ferrelltodd
Jul 24, 2005 01:22 AM
