Odometer Blinking?? Suggestions Welcome
Old Jan 11, 2009 | 01:57 PM
Jst4fun's Avatar
Default Odometer Blinking?? Suggestions Welcome
Hello All,
Last weekend pulled my instument cluster to replace the little backlight bulb.
All went well, very simple procedure, extremly satified the illumination was back!
Now the odometer continues blink/flash!
Its driving me nuts![:@] I hate having something function abnormally on my vehicles, I know its small but would like to correct it.
Any suggestions on how to stop the flashing?
Thanks!
Regards,
Nick
Old Jan 11, 2009 | 03:44 PM
Default RE: Odometer Blinking?? Suggestions Welcome
You will need to go to a dealer or a mechanic that has a Test Book scanner and have them reconnect the speedo to the ECU.
Old Jan 11, 2009 | 03:49 PM
Night Train's Avatar
Depending on your independent qualifications, this situation calls for the precise placement of
A. Duct Tape
B. Electrical Tape - color of your choice
Enjoy
Robert
Old Jan 11, 2009 | 06:29 PM
Jst4fun's Avatar
Mike when you say "reconnect the speedo to the ECU" would that be to stop the flashing?
The odometer is working properly, miles are being added as normal.
A trip to the dealer will stink due to replacing a two dollar bulb!
Will it stop blinking after time (wishful thinking)?
Thanks
Old Jul 28, 2009 | 04:12 PM
ace00959's Avatar
Default odometer blinking
Wife just left on vacation. After about four hours of driving she calls to tell me that the odometer is blinking.?? I searched on this forum without much luck. We have owned the vehicle for about a year, no problems other than three amigos. I changed the front driveshaft two days ago. Any relation to problem? What coud cause the odometer to blink, is it serious, and how to fix it(other than tape across display)? Thanks everyone.
A.J.
Old Jul 28, 2009 | 08:52 PM
roverguy7's Avatar
the odometer needs to be reset, you unpluged it, or at least disturbed it and it lost what it knew. the dealer will resynch it to the secondary odometer that lives in your bcu. and as to ace, did it just start happening while she was driving? usually its caused by low voltage or ecus being disconnected, but i dont see how the driveshaft has anything to do with it
Old Jul 28, 2009 | 09:29 PM
ace00959's Avatar
Question
Dave,
Thanks for reply. I don't know how the odometer could have been disturbed. The blinking has not been present before now, no repair other than driveshaft recently repaired. It came on sometime during the drive. She did not know exactly when. What could have occurred to bring this problem? Just a computer glitch? ecu failure? Is it indicative of other problems possibly? As for the 3 amigos, they have been present for some time, not too worried about that. I hope to get it repaired by end of summer. Appreciate the help.
A.J.
2001 Discovery II
82,000 miles
Old Jul 28, 2009 | 11:55 PM
roverguy7's Avatar
ive seen it happen for no good reason at all, but as i said before, its usually with a low voltage issue. could be a bad ground or something... but id try the reset first and see what happns
Old Sep 20, 2014 | 09:36 PM
taylorshann's Avatar
8th Gear
thanks guys I replaced the motor in my 99d2 and had my odom, start flashing also but I have not got any dealers near me can a chev or ford garage hook to it or does it take a specialized rover com.
humroot
Jul 16, 2012 09:28 AM
lr2001silver
Jul 15, 2012 06:54 PM
Off Topic
Dec 16, 2005 03:44 PM
Off Topic
Oct 11, 2005 11:30 PM
Off Topic
Jun 8, 2005 09:57 PM
