off-road mods
RE: off-road mods
I'm new to Discos(three days)
I'm running double cardin shafts front and rear on my defender and I cut the rear sway bar and welded a bigger section of pipe to it so that the two pieces slide together and apart held together with a big lock pin. I'm not running a front sway bar.
Maybe some of this can spin over to the disco. I have yet to think about mods and may not even mod it.
Have you checked with great basin rovers?
They make nice stuff and have iliminated the spacer that was needed before on the defender.
RE: off-road mods
maybe they are stronger than they look, when I look at them all I see is a BMW ride control component that does not belong on a serious off-road vehicle. Do D90s and D110s use them also? The rubicon can be ran by a stock jeep, but if your rotoflex has survived lions back and slick rock at moab then I own rotoflexes an apology.
RE: off-road mods
ORIGINAL: NiteTrain
mike, it will just be used for light to moderate trails (31 inch tires) A big piece of rubber has to be weaker than a steel U-joint. The rotoflex on my bmw serves a purpose but is it really needed on a off-road vehicle? And yeah I would be converting to a U-joint, should of specified that in original post.
