Off-road tips
Have a stick 03 disco
thinking of joining a off-road club here in Canada however any tips ?
Will a stock 03 disco handle light medium off-roading ?
Any recommendations on the basic upgrades if any ?
How well do these trucks do on stock for off-roading etc ????
- 2003's can simulate a locking diff by gently easing on the emergency brake while applying power temporarily.
- Use your cheap floor mats under your tires if you get stuck.
- There are winches that snap in to your rear trailer hitch. Do you really care forward or backward when getting unstuck?! The beauty of the snap-in trailer hitch winches is that you can leave them in the garage while commuting and simply snap them in when 4x4'ing.
Biggest problem with running an entirely stock rig...you will eventually get stuck...and you don't have quality recovery points. You basically have none in the front and only the possibility of one in the rear, if you use the trailer hitch mount. If your part of a group/club, you'll have plenty of folks who can pull you out...but you need somewhere reliable/safe to hook too. The plastic bumpers are as fragile as an egg shell, so be careful there, too.
Other than that, l say, have at it! You'll probably be somewhat impressed with its preformance. CDL would probably help some, but if you're doing mild stuff...you'll be fine. Well, you'll be fine until you get hooked on wheeling and the upgrades start...then watch out...your bank account will then tend to exist. And will be answering the..."Will 35's fit without a lift" question...lol.
Good luck, and have fun!
Brian
Brian
Only works if it's the rear wheels springing, but yes
Check with the club you plan on wheeling with first. Some have requirements you must meet before you can go off road with them.
Small List:
Recovery Points Front & Rear
Fire Extinguisher/First Aid Kit
Working Emergency Brake
CB Radio (channel #4) or a hand held 2 way radio
Since it's a stock D2 the main upgrade I'd do = tires. OEM style street tires DO NOT do all that well off road. I'd grab at least a BFG A/T, Goodyear Duratrac.
Small List:
Good tip guys, I think the first upgrade would be tires
what are you guys using for tires ?? And size for a stock discovery ?
Also the recovery points ? Is there points you can buy and bolt on to the truck ??
There is a lot to picking lines and managing momentum. I have an 03 with a locking center diff, lift, winch, tires.... did an off road learning day. Got stuck plenty and learned a lot, an other dude in a stock older Disco on winter tires was making it around the course. He picked lines that worked and knew how to manage momentum and throttle.
I would hop in with the focus on having fun and learning.
Suggestions for recovery points and traction aids are spot on.
My club says that all I need is a good working condition vehicle. If it doesn't have lockers, it has to have an ABS/traction system that works. I need a first aid kit and at the very least a rear hitch. The more hardcore trails they go on are optional for those with more stock vehicles. Some of those people end up staying somewhere easy and setting up a BBQ.
Tires are on any type of vehicle the most important. The second for a D2 is the ABS/traction system. If the amigos are on, you won't have the ability to do much at all.
I've heard you can get a 265/65R18 in the wheel wells without rubbing, but I'd probably go with a slightly smaller tire on stock suspension. Stock 18 size is 255/55, there are some pretty good all terrain tires in that size, namely the BFG KO2.
I don't know of any recovery points that you can buy and bolt on to a stock truck. You'll need a steel bumper in the front, in the rear you can use the rear hitch.
If you do go out with a club, they will most likely put the more inexperienced drivers in the middle, that way they can be pulled back by someone with straps or a winch. Plus, it allows you to observe other experienced drivers' lines and how much power they use etc.
In the end, ask them what you NEED to have vs what is helpful to the group as a whole. Go out, have FUN and LEARN. Take those learnings and improve you rig where it's needed.
