Oh Cmon!!
I wouldn't replace the manifold over this... if nothing seems to work, take out the manifold and try again. You'll have more space, and then you have the liberty of working the other side and/or spraying fluids to help you get it out. A rethreading tap might be ok to use, but as said above, I wouldn't use a cutting tap. Maybe there is a barrel type tool you can insert, and tighten to expand the barrel, and then twist to expand its grip
Also try using an angled pick and tackle it thread by thread
You could also try burning it out with a low-temp torch, using a pick to remove the residue, and then chasing the threads clean afterwards. Might be easiest to focus the burn on one particular area so that you could collapse the remainder of the piece inwards after that part was removed.
I'd regard this approach as a real last resort though.
I've removed the guts of a broken plastic nipple with a pick as well. The plastic was pretty soft in my case so I just took my time and eventually got it all out without damaging the threads.
