Oh God... Write up?
I'm sure everyone would appreciate a write-up as well as more detail on the diagnostic flow; such as how a clang was diagnosed and pinpointed as a top-end/ lifter issue, what was causing the excessive oil temp issue and was it repaired or just an oil cooler installed; what led to the decision to replace the followers without the cam. Just some more detail I guess, especially with such an atypical case it's always great to have more info and diagnostic advice. As an aside the genuine t-stat is a 180, if you have a source for a 165-170 for the stock location that would be great as well.
The customer poured 2! bottles of motor honey in before I even saw the car...
On top of clogging the rocker shafts solid with the glueish substance, the lifters were clogged also, one of the lifters springs had collapsed, so a new set was in order.
I have never replaced a cam with lifter replacement, only replaced lifters with cam replacement, not saying you should/shouldn't just I have not.
The customer was not willing to shell out the money to correctly fix the oil pressure problem, So I tried as best I could to keep the oil as viscous as possible. Rotella 15/40 and the mongo filter from my other post netted me the most drastic change, +10 lbs at hot idle. Oil cooler install did not net my expected result, almost no change in oil pressure.
Now this motor only ticks when the coolant gets to 210* (through my scanner, not raytek gun) So In theory I could replace the stock thermostat with a 180* and maybe the symptom will go away, but the problem is still there. I'm really worried at this point that his oil pump is cracked and ready to blow apart at any min. Cooler thermostats are available as through rover, PEL500110 (Bosch cars end warm up enrichment at 150* f so anything down to that is viable if you are ok with higher emissions, less fuel economy, and maybe shorter cat life.)
(P.S. I believe the stock thermo temp is 88* cel or 192* f)
