oil
Old Oct 17, 2013 | 10:01 PM
ninjaff21's Avatar
Exclamation oil
Just wondering what oil you guys use trying to get an idea of the best one. I'm about to use shell t-5 10w-30. Is that OK to use in the disco? I use to use 5w30 and currently have 10w-40
Old Oct 17, 2013 | 10:53 PM
Madlands's Avatar
I run rotella 15-40 year round here.
Old Oct 18, 2013 | 04:42 AM
gbob's Avatar
take a peek.
https://landroverforums.com/forum/di...aw-poll-62108/
Old Oct 18, 2013 | 06:58 AM
acg's Avatar
acg
I tried Mobil One Syn 10W40. Works great on the newer engines with tighter spec tolerance. But it does not work well with the Buick legacy V8 design on the Disco. Engine has been leaking a little. Will be going to Rotella non-syn 10W40 as liked by many in this forum.
Old Oct 18, 2013 | 09:18 AM
Run T-6 oil with a better then average oil filter like a Mobil1-301 or a K&N 3000 both of which have better filtering material and are about 40% larger then the standard filters.
Old Oct 18, 2013 | 12:27 PM
Madlands's Avatar
I know I've already commented but I wanted to elaborate a little. I live in Carlisle (35min from LR) when not in school at Russellville (just an hr from Little Rock). I have over 220k on my 99 using rotella 15w-40 with a napa gold filter, and it runs like a top.
Both oil and filter are very affordable. I have met some guys around Little Rock that run 20w-50 year round with no issue. The napa gold filter is as good or better than the mobil1 and K&N in my book.
I'm not saying any others are wrong as it's all personal preference. Plus weather is different anywhere you go, what is good in some states may not be best for those in another. Just wanted to point out that I'm in the same area with my results all being good.
Old Oct 18, 2013 | 01:05 PM
dr. mordo's Avatar
You're gonna get a million opinions, the most important thing is don't use w30 oil, because it's too thin for the temps we see in Arkansas. I'd use 5w-40, especially because winter is almost here. 15w40 and 20w-50 don't flow well at all when they're cold, which increases engine wear greatly.
Old Oct 19, 2013 | 12:10 PM
How many time do I have to debunk your oil filter opinions?
NAPA, WIX, Baldwin and Purolator are better oil filters by far and at half the cost.
The K&N oil filter is a Fram, look it up.
The Mobil 1 oil filter is made for extended drain intervals, so unless you are changing your oil and filter every 15,000 miles you are wasting your money buying that oil filter.
I use Rotella 5w-40 all year, 5,000 mile oil changes and I use the oil filters that I stated above and I have 230,000 miles on my ORIGINAL engine, how many miles on your second engine Mike?
Old Oct 19, 2013 | 12:40 PM
ninjaff21's Avatar
I decided today to take back the 10w-30 and I got 10w-40 castrol GTX with a wix filter (my personal favorite)
Old Oct 19, 2013 | 12:44 PM
There you go, dont go more than 5,000 miles between oil changes and you'll be fine.
