Oil in Air Intake
oil on the butterfly at the throttle body, this is caused by the PCV (Positive Crankcase Ventilation) valve on the rocker covers sending engine oil vapour back to the intake - it's a part of emission control. If you were keen to get rid of it you could find a spray of some sort to spray in while the engine is running that would no doubt remove it (throttle body cleaner??). It may also be possible that your PCV is buggered.
Edit: Ooooh, stereo advice even
