Oil all over oil pan -- just oil pan gasket or more?
Old Nov 30, 2015 | 09:59 PM
erick846's Avatar
Default Oil all over oil pan -- just oil pan gasket or more?
Recently, I've been noticing a few more leaks than usual below my 03 Discovery. At first glance, they appear to be randomly scattered along the bottom of the truck, but I got down and noticed that most of the drips were coming off of the oil pan.
Do y'all think it's just the oil pan gasket that needs replacing? Or is there anything above it with which I should be concerned?
Apologies for not being specific I'm not the most mechanically minded but always trying to learn. If it's just the oil pan gasket I'll probably do it myself, if it's anything more than that but still doable I'll assess the feasibility of that too :}
Edit: upon peeking into the engine bay I can visually inspect the valve covers and neither ones are really leaking.
Old Nov 30, 2015 | 10:20 PM
Bom2oo2's Avatar
R U sure it's oil pan gasket, and it's not the crosefix seals on back side of engine block,?
Those seals are not visiable, because Trans housing is covering them, & if they start leaking it seems like gasket is leaking, because drips from back of block & covers back side of oil pan, & drips down ,,,
Check your PCV tube on back side of right valve cover, to see if it isn't clogged, because if it is, puts extra pressure on all gaskets & they start leaking,,
Usually clogged PCV makes crosefix seals to leak ,
Old Nov 30, 2015 | 10:58 PM
erick846's Avatar
How do I check if it's clogged?
Old Dec 1, 2015 | 12:01 AM
toofaroffroad's Avatar
All land rovers leak oil. So the bottom of your engine will have all kinds of oil on it from one leak or another. you need to throw some engine cleaner on there and power wash to clean. Then drive it for a bit and see if you can pin point the oil leak...or leaks.
Old Dec 1, 2015 | 09:19 AM
Bom2oo2's Avatar
The right way is to remove it & clean it, because they are known to clog often, but if you just want to check maybe you can remove hose from manifold side & see if you can blow or suck air out of it easily,, you can feel if it's clogged or partly clogged that way,,
Old Dec 1, 2015 | 09:36 AM
Jagfixer's Avatar
Have you tried tightening the pan bolts?
Old Dec 1, 2015 | 09:46 AM
drowssap's Avatar
x2 tighten the pan bolts then clean it up, make sure you clean the front of the engine in case it is a crank shaft seal
Old Dec 1, 2015 | 11:19 AM
erick846's Avatar
Thanks buds. I'll give the pan bolts a tightening and then check the PCV hose. Much appreciated!
mike111
Jun 2, 2014 08:58 AM
jpmiller
Sep 26, 2012 06:32 AM
SolbergFanBoi
Mar 5, 2012 07:05 PM
Disco Sam
Sep 2, 2011 05:37 AM
Bryan H
Feb 12, 2009 10:59 PM
