Oil Filler Neck Compatibility - Series I/II
Are the oil filler necks compatible between the Disco I and Disco II? Obviously the Series 1 neck is much shorter, but do they have the same threads top and bottom? As far as I can tell, they take the same o-rings top and bottom, and the oil cap itself is interchangeable.
I'm asking because my filler neck broke, and the replacement cost of the Series II neck is about $260 before shipping, but the Series I neck is only like $20. Aside from the inconvenience of the shorter pipe, would I run into any other issues using the cheaper part?
You'd think so, but more often than not....
Anyway, for anybody else seeking this information: I can confirm that the valve cover, filler neck, oil cap, and applicable o-rings are all interchangeable between series 1 and series 2 engines. I actually kind've like the new shorter filler neck on mine.
The following 5 users liked this post by CameraDan:
boston4 (07-08-2020),
Jason Feuerstein (07-09-2020),
JUKE179r (07-08-2020),
MrHSE7 (07-08-2020),
Richard Gallant (07-08-2020)
