OIL FILTER 2003 SE
#21
#22
ORIGINAL: jmt
As an aside, what type of oil is everyone running? Brand and viscosity rating? I am in need of an oil change too.
I'm a little confused though. My RAVE cd says to use 10W-40 for a low compression V8, and 5W-30 for a high compression V8. I thoughtall discos had high compression engines (premium gas), so should I use a 30 weight oil?
#23
ORIGINAL: jmt
The Fram is a PH16 I believe.
Also, you can get drain plugs with magenets on them. Just a thought.
Get a K&N, Mobile 1 or WIX. They aren't that much more, and are a lot cheaper than a new motor.
I run Royal Purple 10W40
#24
on
If you are running a Fram filter and giving out the part number as a suggestion, after OKDiscoguy slaps you, I'll take you off the site.
Never ever use or recommend a Fram oil filter, they are pure junk.
No go buy a Mobil 1 or a K&N 3001 oil filter and apolgize to your truck.
#25
Kswin
04-11-2010 06:56 PM
