Oil leak at crank shaft seal
Old May 20, 2011 | 12:54 PM
gplandrover's Avatar
Default Oil leak at crank shaft seal
My 2004 Discovery has had the front crank shaft seal replaced 4 times in the past 3 months. Is there something that LR is missing?
Old May 20, 2011 | 02:24 PM
0304Disco's Avatar
Sure sounds like LR is missing the ball. My 04 has never dripped an once from this seal with 80K. This isn't to say I don't have other issues!!!
My guess is that it is not the seal. Possibly the crack has a groove worn in it from the seal ( Not likely but possible).
Ask the question how they feel it is coming from the seal and why the feel replacing the seal 3 more times after the first hasn't fixed it. Clearly not the seal boys.
And finally take it so some other then the dealer.
Good Luck
Old May 20, 2011 | 02:48 PM
yloDiscoII's Avatar
I really hope they are not charging you each time they replace the seal? If they'll do it again for free, have them show you the old gasket.
I think Einstein might have been talking about that LR Dealership :"Insanity is doing the same thing over and over again and expecting different results."
Willie 00D2
Nov 6, 2017 03:16 AM
outdoor7or24
Dec 22, 2014 09:31 PM
yloDiscoII
Feb 10, 2010 10:03 PM
djmik2000
Jan 28, 2009 03:58 PM
shark19
May 12, 2008 08:15 PM
