Oil Leak Pic
Oil Leak Pic
I have an oil leak that is pretty heavy, and wanted to get your ideas on where and what the oil leak could be. Not the greatest photo, but this is underneath, drivers side. you can see the Crank Sensor is caked with a couple of years worth of oil.
Just curious to find out if this is something I can take care of myself and what the probable causes are. Any thoughts are appreciated.
How much oil are you loosing per week on average? I check my oil a couple times per week so you should get into the habit of checking and topping off the oil level frequently.
First thing Id do is clean that entire area with some simple green. Clean up all the built up gunk. Then top your engine oil and drive for a couple days or maybe a week then get back underneath the truck and see where the new oil is leaking from. It should be easier to identify the location of a leak if the area in question is clean. Clean the entire exterior oil pan and around it as much as you can reach.
In a best case scenario its either a engine oil pan gasket failure or maybe when the oil pan was re-installed someone did a crappy job with the rtv sealant and thus a leak. Maybe its time to do an oil and filter change? While your at it maybe consider changing out the oil pan gasket and see if that addresses the problem.
I am greasing the front driveshaft this weekend and am planning on cleaning it up. Hopefully that will shed a little light on the subject. I am going to torque the oil pan screws while I am there.
I am just wandering what would throw oil over thecrankshaft sensor. I would think the valve cover, headgasket would be likely.
