Oil Leak Pic
Old Oct 15, 2014 | 04:56 PM
CollieRover's Avatar
Default Oil Leak Pic
I have an oil leak that is pretty heavy, and wanted to get your ideas on where and what the oil leak could be. Not the greatest photo, but this is underneath, drivers side. you can see the Crank Sensor is caked with a couple of years worth of oil.
Just curious to find out if this is something I can take care of myself and what the probable causes are. Any thoughts are appreciated.
Old Oct 15, 2014 | 06:18 PM
TRIARII's Avatar
How much oil are you loosing per week on average? I check my oil a couple times per week so you should get into the habit of checking and topping off the oil level frequently.
First thing Id do is clean that entire area with some simple green. Clean up all the built up gunk. Then top your engine oil and drive for a couple days or maybe a week then get back underneath the truck and see where the new oil is leaking from. It should be easier to identify the location of a leak if the area in question is clean. Clean the entire exterior oil pan and around it as much as you can reach.
In a best case scenario its either a engine oil pan gasket failure or maybe when the oil pan was re-installed someone did a crappy job with the rtv sealant and thus a leak. Maybe its time to do an oil and filter change? While your at it maybe consider changing out the oil pan gasket and see if that addresses the problem.
Old Oct 16, 2014 | 06:38 AM
I am greasing the front driveshaft this weekend and am planning on cleaning it up. Hopefully that will shed a little light on the subject. I am going to torque the oil pan screws while I am there.
I am just wandering what would throw oil over thecrankshaft sensor. I would think the valve cover, headgasket would be likely.
Old Oct 16, 2014 | 06:43 AM
drowssap's Avatar
I would think the valve cover, headgasket would be likely. check the back of the vc gaskets
Old Oct 16, 2014 | 11:09 AM
I will take a look at that this weekend. There is no coolant in the oil so I am hoping it is not the head gasket.
Old Oct 16, 2014 | 11:10 AM
I don't lose much, but frankly don't drive it much.
Old Oct 16, 2014 | 01:44 PM
Fivespddisco's Avatar
I say valve cover and vallypan gasket. Its hard to leak oil from the head gaskets. Not a lot of oil in that area.
Old Oct 16, 2014 | 01:59 PM
I hope your right.
Is there a possibility of the rear main seal leaking that high up?
Old Oct 16, 2014 | 02:43 PM
drowssap's Avatar
They are correct I meant to say valley / valve covers
Old Oct 16, 2014 | 03:31 PM
Originally Posted by CollieRover
I hope your right.
I don't think so.
