oil leak- what's that thingy???
so, after doing a Florida-NY round-trip recently, the Disco has sprung a pretty healthy oil leak. as best as I can trace it, it looks like the leak is coming from the bolty/thingy near the oil filter / front of the sump. no luck with looking in the Rave, maybe I just didn't see it. any leads as to what this is called? does it have it an o-ring that needs replacing? RTV?
thanks...
thanks...
Photos would probably help, just to make sure we are on the same page. If it were a 2003 or 2004, I'd think you're talking about the bolts where the oil cooler lines are missing, but a 2000 should have the lines hooked up there.... unless you got a new engine or oil pump at some point and a newer one was used?
Can you ID from this part illustration?
Discovery II Engine Oil Pump - Rovers North - Classic Land Rover Parts
jamestfl (05-16-2016)
that part #8 on the list, that was my jetta's problem, id loose a quart of oil in a few days. and you could see it dripping from the filter fast when the engine was running. luckily it was pretty easy to get to and replace and never had a problem sins.
