Oil Leaks - i am sure I am not the first one
Old Feb 19, 2017 | 02:43 PM
  #31
chubbs878's Avatar
I saw oil in the same place on mine (bw sump & trans) with a fresh oil pan gasket & really the only way it's going to leak back there is at the seal from what I recall.
Yes, removing the oil pan and replacing the front seal is a Bi***. You couldn't pay me to do that again, short of having the truck up on a 4-post lift but never again will I lay on my back & drop the oil pan; you have to be bound & determined to complete that exercise but I was already 2-weeks in on a head gasket replace, I knew the front seal was shot, plus a lot of crud fell into the open valley which I flushed with oil so had to clean the sump out & ya, that was some work. I think I removed the pan starting at 9:00 pm and had the new crank seal in, pan gasket on & bolts tourqued to spec by noon the next day with a 1-hour break. For some reason it took 3 attempts to get the sump seated correctly so that set me back 2-hrs.
Old Feb 19, 2017 | 03:04 PM
  #32
sayeedA's Avatar
That's sounds scary!
May be i will go around and tighten oil pan bolts, get rid of synth oil add some sort of oil sealers to band Aid for the time being. see if that helps.
Spencerfitch
Sep 27, 2020 12:17 PM
austinlandroverbill
Aug 23, 2015 01:03 PM
aussiestuckintexas
Nov 2, 2014 02:04 AM
FlyingZebra34
Apr 22, 2013 12:07 AM
discoboy
Dec 20, 2012 02:24 AM
