oil light comes on briefly in the morning
Am using 10/30 synthetic. I change it every 4-5 k but top it up often. Is it hard to do the oil pump? Where can I get a good one? Thanks mike.
on
You can buy a good quality oil pump repair kit from British Parts of Utah. If you are mechanical, no, it is not hard, most people replace the timing change if it is over 100,000 miles.
There is also a slight possibility that your oil pressure switch is bad, might be worth doing an oil pressure test before you do anything.
If you have any questions, send me your number and I'll call you.
If you dont hit the throttle how long will the oil light stay on?
What oil filter are you using? Cheap ones dont have a anti drainback valve and you are priming the whole system each and everytime.
In cold weather it is normal for the oil light to stay on a few seconds longer.
Switching to a 5w-motor oil will pump much faster when cold.
