oil in my intake manifold
probably not, would have to be coming from one of the two crankcase ventilation tubes, there is a low vacuum tube on the drivers side that is usually before the throttle plate and the high vacuum side after the throttle plate. those would be the only place for oil to get into the upper plenum of the intake. As far as I can tell. Here is diagram
