Oil pan
Trying to drop my oil pan to change my front cover gasket. I have all the bolts and nuts off. I think there was 24 bolts and 3 nuts. I've been trying to pry this thing down for half an hour but she just won't budge. What am I missing?
I'm not sure on the count, but did you get the ones pointint to the read of the car, around the rubber inspection hole plugs? The two running straight up at the bell housing? Did the previous person etc the whole pan?
Just be careful when prying on aluminum...especially of this age. Easily cracked. We had a michigan land rover group member just crack his in the same method. Rubber mallet is a much better option, tapping from side to side. Glad prying worked out for you.
Brian.
Brian.
