Oil pan won't drop
Greetings, trying to get the oil pan off so I can change the front cover gasket on my 2002 DII. I got all of the bolts and nuts off, but the pan won't budge. I carefully tried to put a flathead screwdriver in different places. It moved a little, but would not come off. Any suggestions would be appreciated
How many bolts did you remove? IIRC there are 14. Two of them are somewhat hidden at the bottom.
Edit: Totally wrong count number. I was thinking back to the post of separating engine from transmission that slightly involved the oil pan.
Look at these photos and see if you missed any of the bolts.
Land Rover Discovery 2 II Oil Pan 1999 00 01 02 03 04 Used | eBay
