Oil Plug (Bolt) WILL NOT tighten!!!
So, as I am changing the oil for the first time in this new-to-me truck, the oil pug felt a little funny coming out, but on its way in.... It screws all the way in, but will not tighten. Just spins around. The threads on the bolt seem fine. So, I slapped on a rubber gasket, and tried tightening it up that way. Still, will not tighten. Just ever so slightly. I got no choice now, but I guess this is yet another "common problem" on these fine vehicles? So, I need to have the oil pan re-tapped for a larger thread size? What would that be, does anybody know? Thanks
I don’t think this is a common problem on these. I think someone either stripped the threads in the oil pan, or installed the wrong plug. If the pan is stripped you will probably need to remove the pan to repair it. It won’t be a big deal but you shouldn’t use your vehicle until you fix it. An oil plug that falls out will really ruin your day.
You can repair it without removing the oil pan. Get a spiral flute tap so it pulls the shavings out of the hole instead of pushing them into the oil pan.
Not a bad idea to then pour a quart of sacrificial oil thru with the plug still out just in case a small shaving got in. I've had no issue with this method in the past.
Yeah, I got this rubber thing. Haven't installed it yet, but got it in the glove box. Drove a few miles so far, with the original plug in.
Dude, it's funny that you mentioned it, I just thought the same thing earlier today, after having paid visits to Autozone and Advanced Auto, I went to Home Depo and got the tape. Will try tomorrow. I plan to remove the plug half-way, so that the oil does not drain out, and see if I can fix this for the next few thousand miles. And then we'll see. Really have a lot going on right now. But I do like the truck so far, despite the stupid little things that should not even happen in the first place.
