Oil Pressure Test: Where do I connect the gauge?
Hey everyone,
I bought a cheap oil pressure gauge and want to get oil pressure readings on my 04’ D2. No reason to believe there is an issue, it’s more because I like learning how to do stuff on the truck and want to gauge the health of the engine.
See the picture below. Which one of the these do I remove to connect the oil pressure gauge?
I am having a hard time removing the electrical connector on the top one (assume that is the sending unit?).
If the the red arrow is the only option, this will take a little longer...
Thanks!
Thanks!
You can't remove the oil pressure switch, otherwise your oil light will be constantly on. Above the switch there is another port which is plugged. This could be used, but the space is very tight and it needs to be extended in order to have enough space. I recommend using the unused oil cooler port (yellow). This port is before the oil filter, but the pressure drop is negligible. In both cases you need an adapter first. Threads are: M20x1.5 (yellow), 1/2"x20 UNF (red). Another option is to use a sandwich plate.
arains44 (12-13-2020)
@Discorama I think I have the right adapter for the oil cooler port. That is by far the easiest access point.
Ran out of time to knock this out today, but I’ll do it ASAP and post results!
Thanks!
Thanks!
in that case you can get a oil filter adapter. I’ve had good luck with glow shift
I used a Glow Shift Sandwich plate and put the gauge in to that. If my pressure was marginal I was going to mount the gauge in the engine bay for frequent checkups, but thankfully it was pretty good so I decided to disconnect it and remove the plate, but I still have it for the future if needed. Might spring for a digital sensor/gauge in the future and mount it in the cabin but no plans for that right now.
Richard Gallant (12-14-2020)
@redwhitekat I am just checking pressure, not installing a gauge.
It sounds to me like using the blocked off oil cooler port is the way to go. I ran out of time to put the gauge on yesterday once I got feedback on that on this thread.
So just clarifying, I’m not installing a gauge, just testing pressure.
ok well depends on the kit you got it may not have the fitting to go on those ports
I bought a oil pressure kit gauge off Amazon and it came with a bunch of fittings. None fit on the disco
I managed to find a fitting from my black iron gas fittings that went into the oil pressure sensor Port but not well
you can use any of those ports as long as your gauge fitting threads into it
It’s a good piece of mind what your doing. Let the truck run or drive it for a hour or so let it sit for 10-15 after to let oil drain back to sump ( or oil will come out when you take any of those ports off messy ) and then take your oil reading when the oil is hot. If it’s anywhere near low it’s a good time to do oil pump gears and front timing cover
arains44 (12-15-2020)
