Oil pressure wire
Old Mar 23, 2020 | 08:52 AM
redwhitekat's Avatar
Default Oil pressure wire
Ok I’m bad at reading auto wiring diagrams
can anyone tell me how and where the oil pressure wire is run ? Mine got pinched during cdl install by a shop and instead of trying to find where the wire is bad I would be easier to run a new one
looking at this diagram does the ground wire go from the instrument pack oil light directly to the switch ? Looks like ground wire C0230-6 WN 0.5D ?
Old Mar 23, 2020 | 10:09 AM
mollusc's Avatar
C0230-6 is a connector and pin ID, not a wire identifier. WN is the colour of the wire (White/browN), in this case.
The D2 electrical library confirms that "the oil pressure warning lamp is connected to the instrument pack from pin C0230-6 on a WN wire to the oil pressure warning switch" (p.4.136).
C0230 is on the instrument pack itself.
Old Mar 23, 2020 | 12:14 PM
enb54's Avatar
Additional information for those interested, comes from some LR3/D3 documentation but should be correct for D2 also...
Wire Insulation Colours for Land Rover
BK or B Black
BN or N Brown
BU or U Blue
GN or G Green
GY or S Grey/Slate
OG or O Orange
PK or K Pink
RD or R Red
VT or P Violet/Purple
WH or W White
YE or Y Yellow
The insulation colour is indicated on the wiring diagram followed by the wiring conductor diameter in mm, that is; RU, 0.5D is Red (dominant colour) with a Blue tracer and the wire is 0.5mm in diameter. Also LGB, 0.5D, 700 means Light Green with Black tracer, 0.5 mm conductor diameter, 700 mm in length. Hope this helps someone...
Old Mar 23, 2020 | 02:49 PM
thanks for the pic. That really helps
Old Mar 26, 2020 | 11:26 AM
Thanks for all the help
did this today pretty easy straight forward
Old Mar 26, 2020 | 12:40 PM
XRAD's Avatar
so did it fix the issue?
Old Mar 26, 2020 | 02:36 PM
yes. I will have to find where originall wire went bad
Old Mar 26, 2020 | 06:49 PM
XRAD's Avatar
Cool. Glad to see someone actually fixed a disco 2 issue in less than 7 posts!
Old Apr 23, 2020 | 07:52 PM
im trying to get more familiar with the rave and electrical section. I cannot find this pic above not even sure if there is different sections of race.
Where exactly is this picture ???
Old Apr 23, 2020 | 08:30 PM
OverRover's Avatar
Those pics are NOT in the RAVE " Workshop Manual " under ELECTRICAL.
They are in a separate section called " Electrical Library "
Most full versions of RAVE will have all the sections but....
You can see them under
> CONNECTOR
> CIRCUIT REFERENCE NUMBERS
HERE
>>> https://discoii.files.wordpress.com/...al-library.pdf
