Oil pump service... Missing part?
Old Jul 9, 2019 | 05:41 PM
Drducttape's Avatar
Default Oil pump service... Missing part?
Missing part...
I'm doing a rebuild on the ole 4.6. Disassembled the oil pump yesterday in order to clean and inspect, pulled the bypass and relief plugs, removed the springs, found the relief valve, didn't find a bypass valve.... Check the attached screenshot, that's what is missing.
What I'm hoping is that someone has a picture of one so I know what I'm looking for when I go to scour the abyss of my workshop.
What does it look like? What is it made of?
Thank you all in advance!
Old Jul 9, 2019 | 10:56 PM
FlyingZebra34's Avatar
I've got a front cover for a 4.6 sitting in the bin at work. I'll pull it apart and photo it tomorrow.
Old Jul 9, 2019 | 11:10 PM
Drducttape's Avatar
Thank you!
Old Jul 10, 2019 | 05:07 PM
Which port do you need pictures of?
Old Jul 10, 2019 | 08:00 PM
Drducttape's Avatar
The guts in this port:
Old Jul 14, 2019 | 10:32 PM
Drducttape's Avatar
What happens if there was nothing but a spring in that port? This component acts as a pressure regulator for the oil system, no?
Old Jul 21, 2019 | 12:25 AM
Drducttape's Avatar
The reason I ask is that in order to get the cap off that port, I needed to send a thin flexible screwdriver through the back end of the port to push the cap out. I didn't encounter anything but a spring in that hole, and when it finally came loose, it did so in a hurry and the cap and spring flew out the other end. My above question may seem silly, but I am seriously asking if anyone understands this system, and would know the effect or reason for having no valve in that port.
Still needing info, as the project is on hold.
Old Jul 21, 2019 | 08:30 AM
redwhitekat's Avatar
Do a quick search disco 2 oil pump replacement
you will see one from Atlantic British they have the whole assembly on the bench. That might answer your question
Old Jul 27, 2019 | 10:28 AM
Drducttape's Avatar
Thank you, but unfortunately I was unable to locate what you are describing.
I purchased a whole used cover assembly off a 4.6 with a buggered oil pump, just to see what was inside. See pictures :
I guess this could explain why the engine failed.
Old Jul 27, 2019 | 11:53 AM
So this part was missing from your oil pump assembly?
Did it come like that from factory or you think over the years someone messed with it
