Is this the Oil Pump that is so bad?
Old May 6, 2011 | 09:20 PM
Forrest's Avatar
Default Is this the Oil Pump that is so bad?
Hello everyone,
So I'm replacing my Valve Cover and timing cover gaskets and noticed the crankshaft gear is inside what I beleive is the oil pump. If this is in fact the oil pump, what is all this talk about everyones oil pump going out. This type pump is about as hard core as it gets..............
C'ya,
Attached Thumbnails Is this the Oil Pump that is so bad?-timing-cover-inside.jpg   Is this the Oil Pump that is so bad?-oil-pump-inside-timing-cover.jpg
Old May 6, 2011 | 10:06 PM
bosshogt's Avatar
Its the mis aligned dowel pins on select range of 2003's. The oil gears can also break apart into pieces. If you have the cover off, It may be a good idea to replace the gears from Utah Brit parts. Google it they are one of the only place to buy the rebuild kit.
Old May 7, 2011 | 07:09 AM
vandev's Avatar
Default yep
thats it.. my gear had a crack in it and could only see when i pulled out and was pulling on it. Whats the shape of the cover surface? is it scored at all or does the face and cover plate look the same? Let me know as i have mine apart also....may have to buy a rebuilt one from over the pond as they are about $200.00 cheaper that here.. Let us know.
Thanks Chris
Old May 7, 2011 | 08:51 AM
Forrest's Avatar
Forrest has about 88k miles and the real reason for this project was the leaking Valve Covers. I thought it would be good to replace the timing cover gasket as well; I'm the second owner and got him with about 49k. Anyway, the gears were fine and the cover was straight and not cracked.
So the oil pump problem is just the 03 year model?
Thanks,
Old May 7, 2011 | 09:05 AM
jafir's Avatar
Mostly the 03. Some people with other years have too. It's actually the block that is bad.
http://www.landroverclubvi.com/uploa...ilures_sec.pdf
Old May 7, 2011 | 09:14 AM
vandev's Avatar
Default hey there...
Thanks,
Take a picture of the inside of the cover and cover itself that house the gears...look for scoring and in the rebuild guide it gives the clearence you should have to be in speck... If you have gone this far you might as well check it really good...
Chris
Old May 7, 2011 | 10:12 AM
That is one of the dirtiest engine I have seen in a long while, you may want to look further, that isn't v/c gasket leaking, they leak to the rear of the engine.
Also before reinstalling the intake manifold, check/tighten the lower manifold bolr, they tend to vibrate loose. Might also consider using some red Lock Tite on the 6 upper bolts and torque to specs.
DiscoTanB
Aug 13, 2015 08:10 AM
boris_gti
Oct 5, 2011 10:28 AM
josephnone
May 29, 2011 07:42 PM
oljohnboy
Sep 14, 2009 03:01 PM
Bene
ROAMING WITH FRIENDS
May 11, 2005 04:33 AM
