Oil pump and timing chain
Old Dec 9, 2019 | 11:23 AM
blakslee720's Avatar
Default Oil pump and timing chain
I’m about to do the front cover gasket and have already taken the heads off. My 04 disco has 166k miles on it.
My question is, are the timing chain, gears and oil pump gear NECESSARY items to replace at this time or just “may as well because it’s apart.”
I’m asking because I’m on a tight budget, have way too much into the car already and need to sell it. I actually had a buyer lined up when the timing chain gasket went and leaked coolant into the oil.
Old Dec 9, 2019 | 11:52 AM
Sixpack577's Avatar
Replace the chain($30), timing gears should be ok.
Remove the oil pump cover and check to make sure the oil pump gears haven't cracket/broken in pieces(common problem).
Oil pump is also cheap.
Old Dec 9, 2019 | 11:57 AM
Thank you. I’ll wait on the pump gears then
Old Dec 9, 2019 | 12:59 PM
Extinct's Avatar
If you want you can send us a pic of the chain once you have the cover off - show flex by pushing in on it till tight. BTW, I have never replaced one and never had a failure - 12 Discos...
Old Dec 9, 2019 | 02:21 PM
Sixpack577's Avatar
The one I took off this 4.0 looked new, but had Alot of slack in it, and slack on both sides.
Old Dec 11, 2019 | 09:42 AM
This seems like a lot of slack to me. I’ll order a new chain
Old Dec 11, 2019 | 09:54 AM
Sixpack577's Avatar
Have you removed the inner cover and checked the gears?
Mine looked ok, until I removed them, and found that the big gear was actually broken into 3 pieces.
I replaced the cover and pump gears.
Old Dec 11, 2019 | 10:01 AM
not yet. That will be tonight
KingKoopa
Jan 28, 2017 09:52 AM
robert.juric
Oct 4, 2016 12:29 PM
sumeet
Jun 9, 2015 01:11 PM
ihatemylandrover
Apr 24, 2013 07:47 PM
Moxierover
Dec 4, 2012 06:24 PM
