oil question
So I just put Mobil 1 synthetic 5w-30 in my D2, when I changed the oil the other day. But I took a look in the manual and it calls for a rating of ACEA A2. The Mobil 1 synthetic is rated ACEA A1. Is this a problem?
Mobil 1 5w30 IMO is not suitable for a flat tappet engine designed in the 60's. It has low level of anti-wear additives as required by the newer oil specs for roller tappet engines. Most people who know oil don't rate Mobil 1 5w30 very highly, it is probably their highest volume oil and where they make their money so it is very "cost optimized", some of their other oils are much better at the same price or a bit more money. You are fine for now but next oil change switch over to any of the following synthetics: Mobil 1 5w40 TDT, Mobil 1 0w40. Rotella T6 5w40, Mobil Delvac 1 5w40, Mobil 1 10w40 HM, Mobil 1 10w40 truck and SUV, Rotella T5 10w30, castrol syntec 5w40, mobil 1 10w30 EP. There are obviously others too but you want either a heavy duty engine oil or a "european" oil.
Used Mobil 1 for a long time and have since switched to the Rotella synthetic also. Make sure you use a good filter like a Mobil 1-301 or a KYN 3001, both about 40% larger in size and filtering media.
Thanks. I was looking for an A2 rating at the store and could only find A1 or A3 and didn't know which one was better. It sure seems like the A1 rating would be best.
I'm pretty sure I checked all the oils and could not find an A2 rating. It was either A1 or A3.
My oil filter is a Cooper from AB.
Maybe a silly question, but....
If I want to switch to synthetic oil on my next change, do I need to do anything special in the transition? Or, just drain the old "natural" oil and replace with new synthetic oil and a new filter? I would guess that there is a residual amount of the old oil and the system, even after draining it. Is that small amount a "don't care" issue?
disco12
Mar 7, 2006 01:10 AM
